Introducción
This guide will show you how to patch a shaped baffle on your Nano Puff ® Jacket. The baffle we’ll be repairing in this guide is a rectangle, but the process is the same for any shape. In this guide we’ll show you how to patch the baffle without deconstructing the garment. This means that the repair stitching will show through on the jacket lining. If you’d rather not have the stitching visible, check out our Opening a Jacket Guide, and go through those steps first, before you follow the steps in this guide. (Opening the jacket makes this repair more difficult and time consuming). If you choose matching thread, your repair thread in the lining should hardly be noticible, but the choice is yours. New to sewing? Check out our sewing glossary.
For replacement parts or further assistance, contact Patagonia Customer Service.
Herramientas
Partes
Examine the damage on your jacket, cutting off any loose threads and freeing any debris
Choose some patch fabric.
Select thread that matches your patch fabric, and load it into your sewing machine.
Select thread that matches the lining of your jacket, and load it into the bobbin of your sewing machine.
Set your iron to the appropriate setting—in our case, nylon—and iron your patch fabric to smooth out any wrinkles.
Position the template on the patch fabric, leaving about ¼ or ½ inch of extra fabric around the edges.
Cut out the patch, leaving 1/4 or 1/2 inch of extra fabric around each side of the template.
5 personas más completaron esta guía.
