Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Installing Sewing Machine Bobbin
Qué necesitas
    1. Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: paso 1, imagen 1 de 2 Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: paso 1, imagen 2 de 2
      • Use your finger to open the bobbin door below the presser foot.
      Pregunta a FixBot
      Agregar Comentario
    2. Installing Sewing Machine Bobbin: paso 2, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 2, imagen 2 de 2
      • Align the hole in the bobbin spindle over the peg in the bobbin case.
      • Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
      • Take the loose thread end and slide it through the slit on the side of the bobbin case.
      Pregunta a FixBot
      Agregar Comentario
    3. Installing Sewing Machine Bobbin: paso 3, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 3, imagen 2 de 2
      • Slide the thread from the slit straight up along the groove and into the open hole on the bobbin case's side.
      Pregunta a FixBot
      Agregar Comentario
    4. Installing Sewing Machine Bobbin: paso 4, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 4, imagen 2 de 2
      • Keeping the bobbin in place, turn the bobbin case so that the back is facing you.
      • Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
      Pregunta a FixBot
      Agregar Comentario
    5. Installing Sewing Machine Bobbin: paso 5, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 5, imagen 2 de 2
      • Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot.
      • Align the metal arm on the bobbin case so that it sits in the slot in the machine.
      • Release the bobbin case.
      Pregunta a FixBot
      Agregar Comentario
    6. Installing Sewing Machine Bobbin: paso 6, imagen 1 de 2 Installing Sewing Machine Bobbin: paso 6, imagen 2 de 2
      • Close the door on the compartment below the presser foot.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
7 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
91,032 Reputación
142 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 123
71,603 Guías creadas
2Guía Comentarios
Love it! Thank you for posting this as my wife has had to fix things on her sewing machine and it's good to have a reference other than Youtube where you can sit down and read it and make adjustments accordingly!
Alex - Contestar Compartir
Thank you for giving a good detailed answer that I had with the insertion of the bobbin on the sewing machine. I took a crash course today, came home and this evening decided to go through what I had learned and ran into a snag. I was able to overcome what was incorrect. Again, thanks a bunch 🧵
Felicia Jones - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 88
Ultimos 30 días: 325
Todo El Tiempo: 60,705
