Saltar al contenido principal
PSP 2000 Memory Stick Slot Replacement
Qué necesitas
  1. PSP 2000  Memory Stick Slot Replacement, Battery: paso 1, imagen 1 de 3 PSP 2000  Memory Stick Slot Replacement, Battery: paso 1, imagen 2 de 3 PSP 2000  Memory Stick Slot Replacement, Battery: paso 1, imagen 3 de 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000  Memory Stick Slot Replacement, Front Casing: paso 2, imagen 1 de 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000  Memory Stick Slot Replacement: paso 3, imagen 1 de 2 PSP 2000  Memory Stick Slot Replacement: paso 3, imagen 2 de 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000  Memory Stick Slot Replacement: paso 4, imagen 1 de 2 PSP 2000  Memory Stick Slot Replacement: paso 4, imagen 2 de 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
  5. PSP 2000  Memory Stick Slot Replacement: paso 5, imagen 1 de 2 PSP 2000  Memory Stick Slot Replacement: paso 5, imagen 2 de 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
  6. PSP 2000  Memory Stick Slot Replacement, Display: paso 6, imagen 1 de 3 PSP 2000  Memory Stick Slot Replacement, Display: paso 6, imagen 2 de 3 PSP 2000  Memory Stick Slot Replacement, Display: paso 6, imagen 3 de 3
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
  7. PSP 2000  Memory Stick Slot Replacement: paso 7, imagen 1 de 3 PSP 2000  Memory Stick Slot Replacement: paso 7, imagen 2 de 3 PSP 2000  Memory Stick Slot Replacement: paso 7, imagen 3 de 3
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
  8. PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: paso 8, imagen 1 de 3 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: paso 8, imagen 2 de 3 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: paso 8, imagen 3 de 3
    • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
    • Slide off the left trigger along with the plastic bracket underneath.
    • Carefully pry off left trigger button using opening tools.
    • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
  9. PSP 2000  Memory Stick Slot Replacement: paso 9, imagen 1 de 2 PSP 2000  Memory Stick Slot Replacement: paso 9, imagen 2 de 2
    • Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally.
    • Gently remove the memory card slot by pulling it straight out.
Conclusión
15 personas más completaron esta guía.
espinks
Miembro Desde 10/18/09
3,472 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-3, Maness Fall 2009 Miembro de Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Miembros
35 Guías creadas
2 comentarios
Thank you, i'am Zakaria Farid from Morocoo
swat4ever2015 - Contestar
would this work for a 2001 model?
James Ginther - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 47
Ultimos 30 días: 218
Todo El Tiempo: 26,117
