Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
This step requires the removal of the warranty sticker. Removing the sticker will void the warranty.  According to the FTC removing this will not void your warranty.
  • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
  • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
  • Remove the sticker using the PSP Opening Tools.
  • Under the sticker is a 5mm Phillips screw needed in the next step.
Este paso requiere remover el sticker de garantia. Remover el sticker de garantia quitara la garantia de tu producto
Localiza el sticker debajo donde deberia ir la bateria que dice: "En: Warranty Void if Seal Damaged."
Remueve el sticker usando herramientas para abrir dispositivos.
Debajo de ese sticker hay un tornillos para desarmadores 5mm de Phillips
[* icon_caution] This step requires the removal of the warranty sticker. '''Removing the sticker will void the warranty'''. According to the FTC removing this will not void your warranty.
[* black] Locate the sticker in the battery compartment labeled: ''"En: Warranty Void if Seal Damaged."''
[* black] Remove the sticker using the PSP Opening Tools.
[* icon_note] Under the sticker is a 5mm Phillips screw needed in the next step.
