Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove two 4.5 mm Phillips screws from the left-hand side of the PSP. Slide off the left trigger along with the plastic bracket underneath. Carefully pry off left trigger button using opening tools.
  • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
  • Slide off the left trigger along with the plastic bracket underneath.
  • Carefully pry off left trigger button using opening tools.
  • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
Insertar traducción aquí
