Introducción
Use this guide to replace the charging port on your Nothing Phone (1).
To remove the charging port in the Nothing Phone (1) you need to remove the battery first.
If your battery is swollen, take appropriate precautions.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach the rear glass when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
Qué necesitas
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Remove the rear glass.
Insert an opening pick underneath the grey plastic cover at the top edge of your phone.
Use your opening pick to pry up the plastic cover.
Remove the plastic cover.
Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the earpiece speaker.
Insert the flat end of a spudger underneath the bottom edge of the earpiece speaker.
Use your spudger to pry up the earpiece speaker.
Use a pair of tweezers or your fingers to remove the earpiece speaker.
Use a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
Use a spudger to disconnect the LED glyph cable by prying the connector straight up from its socket.
Insert an opening pick underneath the recording indicator light cover at the top right corner of the screen.
Use a pair of tweezers or your fingers to remove the recording indicator light cover.
Use a Torx T5 screwdriver to remove the four 4.2 mm-long screws securing the motherboard cover.
Use a Torx T5 screwdriver to remove the four 4.2 mm-long screws securing the daughterboard cover.
Slide an opening pick underneath the right, bottom and left edge of the bottom LED assembly to carefully separate it from the daughterboard cover.
Use a pair of blunt nosed tweezers and carefully fold the bottom LED assembly over to get free access to the LED cable connector.
Insert one arm of a pair of tweezers into the gap at the right side of the connector bracket.
Push your tweezers toward the left edge of the phone to free the closure flap of the connector bracket.
Lift the connector bracket with your tweezers to access the LED connector.
Use a spudger to disconnect the LED cable by prying the connector straight up from its socket.
Use a pair of tweezers or your fingers to remove the bottom LED assembly.
Use a Torx T5 screwdriver to remove the five 4.2 mm-long screws securing the daughterboard cover
Use a pair of tweezers to carefully separate the grey plastic shield from the daughterboard cover and remove it.
Insert the pointed end of a spudger underneath the top edge of the daughterboard cover just above the black rubber guard securing the LED connector bracket.
Pry up with the spudger to release the daughterboard cover from its clips.
Use a pair of tweezers or your fingers to remove the daughterboard cover.
Use a pair of tweezers to remove the black rubber guard securing the LED connector bracket.
Use a pair of tweezers to remove the LED connector bracket.
Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
Carefully slide an opening pick underneath the interconnect cable to separate it from the charging coil assembly and the loudspeaker.
Use a pair of tweezers to fold the interconnect cable to the left like you'd open the cover of a book.
Insert an opening pick underneath the bottom right edge of the charging coil assembly.
Slide the opening along the right edge of the charging coil assembly to separate the adhesive.
Carefully fold the charging coil to the top edge of the phone to access the motherboard cover screws.
Use a Phillips screwdriver to remove the three 4.2 mm-long screws securing the motherboard cover.
Return the charging coil to its original position.
Carefully slide an opening pick underneath the camera cover and flash assembly to separate it from the motherboard cover.
Use a pair of tweezers to carefully fold the camera cover and flash assembly toward the battery.
Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the motherboard cover.
Return the camera cover and flash assembly to its original position.
Carefully fold the charging coil to the top edge of the phone to access the bottom edge of the motherboard cover.
Insert the flat end of a spudger underneath the bottom right edge of the motherboard cover.
Pry up with the spudger to release the motherboard cover from its clips.
Repeat the prying procedure for the bottom left edge of the motherboard cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a pair of blunt nose tweezers or a clean fingernail to peel the pull-tab labeled with an arrow off the battery.
Use the blunt nose tweezers to peel off remaining pieces of the pull-tab from the left battery edge.
Apply a heated iOpener to the screen to loosen the battery adhesive. Apply the iOpener for at least 2 minutes.
Grab the pull-tab and pull up on the adhesive strip to lift the battery out of its recess and swing it up to an upright position.
Remove the two screws securing the loudspeaker:
One 4.2 mm-long Phillips screw
One 4.2 mm-long Torx T5 screw
Insert an spudger underneath the top edge of the loudspeaker.
Use your spudger to pry up the loudspeaker.
Use your fingers or a pair of tweezers to remove the loudspeaker.
Use a spudger to disconnect the fingerprint reader cable by prying the connector straight up from its socket.
Slide a pair of tweezers under the black coaxial cable until they're snug against the metal connector.
Disconnect the black coaxial cable by prying it straight up from the daughterboard.
Use your tweezers to carefully loosen the cable from its routing on the daughterboard and bend it to the side.
Slide a pair of tweezers under the white coaxial cable until they're snug against the metal connector.
Disconnect the white coaxial cable by prying it straight up from the daughterboard.
Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
Remove the SIM card tray.
Use a Phillips screwdriver to remove the 2.9 mm-long screw securing the daughterboard.
Insert the pointed end of a spudger underneath the top edge of the daughterboard.
Use your spudger to pry up the daughterboard.
Use a pair of tweezers of your fingers to carefully remove the daughterboard.
Use a spudger to disconnect the charging port cable from the motherboard by prying the connector straight up from its socket.
Slide an opening pick underneath the top end of the charging port cable.
Slide your opening pick along the charging port cable to separate it from the midframe.
Use a pair of tweezers or your fingers to carefully peel the black foam tape off the charging port cable.
Use a pair of tweezers or your fingers to carefully lift the charging port out of its recess.
Remove the charging port.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate a newly installed battery after completing this guide.
3 personas más completaron esta guía.
