Introducción
Follow this guide to remove and replace the battery on a Logitech K830 keyboard.
For your safety, discharge the battery below 25% before disassembling your keyboard. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Qué necesitas
Insert the pointed end of a spudger under the edge of one of the feet.
Push the spudger underneath the foot and pry up to release its adhesive.
Once you can grip the foot with your fingers, peel it up and away from the keyboard to remove it.
Repeat this step for the remaining three feet.
Use a Phillips screwdriver to remove the eight 6.8 mm-long screws securing the upper case to the lower case.
Insert an opening pick about 2 mm into the gap between the upper case and lower case at the bottom-right corner of the keyboard.
Lift the upper case up by about 2 cm.
Tilt the upper case about 45 degrees so that the keycap letters are upside-down.
Remove the black tape covering the interconnect cable connector.
Use a pair of blunt tweezers to grip the interconnect cable by the blue section close to the connector.
Pull the interconnect cable out of its connector in the direction of the cable.
Make sure the locking tab is in the unlocked position.
Insert the ribbon cable so that the black line on the cable lines up with the white rectangle's edge closest to the cable.
Use your fingernail to move the locking tab into the locked position.
Remove the battery from the keyboard.
If there's any alcohol solution remaining in the keyboard, carefully wipe it off with a coffee filter or allow it to air dry before installing your battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Logitech K830 Answers community for help.
4 personas más completaron esta guía.
Un comentario
Thanks Kyle - absolutely superb instructions - couldn't be clearer.
