Saltar al contenido principal
Installing a Metal Snap Using a Hand Press
Qué necesitas
  1. Installing a Metal Snap Using a Hand Press, Metal Snap: paso 1, imagen 1 de 2 Installing a Metal Snap Using a Hand Press, Metal Snap: paso 1, imagen 2 de 2
    • Get a new stud.
    • Get a new post.
  2. Installing a Metal Snap Using a Hand Press: paso 2, imagen 1 de 2 Installing a Metal Snap Using a Hand Press: paso 2, imagen 2 de 2
    • Measure the diameter of the stud and post to make sure they are the correct size. Ours are 1/2".
    • If you're unsure of the correct size, measure a snap on the piece that you are repairing for reference.
  3. Installing a Metal Snap Using a Hand Press: paso 3, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 3, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 3, imagen 3 de 3
    • Insert the stud into the stud fitting for the hand press. The ridged part should set into the groove on the fitting. When correctly seated, the snap lays flat in the fitting.
    • The stud fitting is marked green.
  4. Installing a Metal Snap Using a Hand Press: paso 4, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 4, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 4, imagen 3 de 3
    • Insert the post into the post fitting for the hand press. The flat part of the post should sit inside the fitting with the shaft pointed out.
    • The post fitting is marked blue.
  5. Installing a Metal Snap Using a Hand Press: paso 5, imagen 1 de 2 Installing a Metal Snap Using a Hand Press: paso 5, imagen 2 de 2
    • Insert the post fitting onto the fitting base of the hand press.
  6. Installing a Metal Snap Using a Hand Press: paso 6, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 6, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 6, imagen 3 de 3
    • Insert the stud fitting into the upper fitting holder on the hand press.
    • Insert the fitting as far as it will go, so that the only visible part is the wider encasement portion of the fitting.
    • Tighten the screw on the side of the upper fitting holder to secure the stud fitting. Tighten the screw about a 1/4 turn past finger-tight.
  7. Installing a Metal Snap Using a Hand Press: paso 7, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 7, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 7, imagen 3 de 3
    • Slowly pull the handle on the hand press to test the range of the fittings.
    • The fittings should just touch when the handle is pulled to its maximum.
    • If there is a gap in the fittings, adjust the height of the fitting base on the hand press by turning it until the fittings touch.
  8. Installing a Metal Snap Using a Hand Press: paso 8, imagen 1 de 2 Installing a Metal Snap Using a Hand Press: paso 8, imagen 2 de 2
    • Mark the fabric where you will be inserting the snap.
    • Align the fabric in the hand press so that the mark rests directly above the shaft of the post.
    • If the fabric is not laying flat, have a friend pull the fabric taut to help keep it flat as you insert the snap.
  9. Installing a Metal Snap Using a Hand Press: paso 9, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 9, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 9, imagen 3 de 3
    • With the fabric aligned, pull the handle of the hand press down in one continuous motion.
    • Apply pressure until you feel the snap give.
    • Setting a metal snap requires force. You will need to pull hard.
  10. Installing a Metal Snap Using a Hand Press: paso 10, imagen 1 de 2 Installing a Metal Snap Using a Hand Press: paso 10, imagen 2 de 2
    • Release the handle of the hand press, and remove the fabric.
    • Inspect both sides of your snap to make sure that it is laying flat and tight up against the fabric.
    • If the snap is not set all the way, reinsert the snap into the hand press, aligning it as it was before, and repeat step 9 of this guide.
  11. Installing a Metal Snap Using a Hand Press: paso 11, imagen 1 de 2 Installing a Metal Snap Using a Hand Press: paso 11, imagen 2 de 2
    • Get a new cap.
    • Get a new socket.
  12. Installing a Metal Snap Using a Hand Press: paso 12, imagen 1 de 2 Installing a Metal Snap Using a Hand Press: paso 12, imagen 2 de 2
    • Measure the diameter of the components to ensure that they are the correct size. These are 1/2" in diameter.
    • If you are unsure of the correct size, measure a snap on the piece that you are repairing for reference.
  13. Installing a Metal Snap Using a Hand Press: paso 13, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 13, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 13, imagen 3 de 3
    • Insert the cap, shaft facing out, into the cap fitting for the hand press. When correctly seated, the cap should not extend beyond the fitting.
    • The cap fitting is marked orange.
  14. Installing a Metal Snap Using a Hand Press: paso 14, imagen 1 de 2 Installing a Metal Snap Using a Hand Press: paso 14, imagen 2 de 2
    • Insert the socket into the socket fitting for the hand press. Place the widest part of the socket facing the fitting. When correctly seated, the socket will snap on to the fitting and sit without being held.
    • The socket fitting is marked in purple.
  15. Installing a Metal Snap Using a Hand Press: paso 15, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 15, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 15, imagen 3 de 3
    • Insert the cap fitting onto the fitting base of the hand press.
    • The cap fitting is marked in orange.
  16. Installing a Metal Snap Using a Hand Press: paso 16, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 16, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 16, imagen 3 de 3
    • Insert the socket fitting into the upper fitting holder on the hand press.
  17. Installing a Metal Snap Using a Hand Press: paso 17, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 17, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 17, imagen 3 de 3
    • Be careful to not let the handle flip back and hit you in the face.
  18. Installing a Metal Snap Using a Hand Press: paso 18, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 18, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 18, imagen 3 de 3
    • The cap is on the bottom of the press. Be sure that you place your fabric face down, so that the cap is on the correct side.
  19. Installing a Metal Snap Using a Hand Press: paso 19, imagen 1 de 3 Installing a Metal Snap Using a Hand Press: paso 19, imagen 2 de 3 Installing a Metal Snap Using a Hand Press: paso 19, imagen 3 de 3
  20. Installing a Metal Snap Using a Hand Press: paso 20, imagen 1 de 2 Installing a Metal Snap Using a Hand Press: paso 20, imagen 2 de 2
    • If the snap is not set all the way, reinsert the snap into the hand press, aligning it as it was before, and repeat step 19 of this guide.
Conclusión
Admire your handiwork!
3 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
89,128 Reputación
131 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,085 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 108
Todo El Tiempo: 20,051
