Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
8BitDo Ultimate Wireless Joystick Module Replacement
Qué necesitas
    1. 8BitDo Ultimate Wireless Joystick Module Replacement, Case: paso 1, imagen 1 de 2 8BitDo Ultimate Wireless Joystick Module Replacement, Case: paso 1, imagen 2 de 2
      • Insert an opening pick into the seam between the left controller grip and main controller body.
      • Pry the grip off.
      • Repeat for the right grip.
      Pregunta a FixBot
      Agregar Comentario
    2. 8BitDo Ultimate Wireless Joystick Module Replacement: paso 2, imagen 1 de 2 8BitDo Ultimate Wireless Joystick Module Replacement: paso 2, imagen 2 de 2
      • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
      Pregunta a FixBot
      Agregar Comentario
    3. 8BitDo Ultimate Wireless Joystick Module Replacement: paso 3, imagen 1 de 3 8BitDo Ultimate Wireless Joystick Module Replacement: paso 3, imagen 2 de 3 8BitDo Ultimate Wireless Joystick Module Replacement: paso 3, imagen 3 de 3
      • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
      • Set the halves next to each other with care not to strain the connected ribbon cables.
      Pregunta a FixBot
      Agregar Comentario
    4. 8BitDo Ultimate Wireless Joystick Module Replacement: paso 4, imagen 1 de 3 8BitDo Ultimate Wireless Joystick Module Replacement: paso 4, imagen 2 de 3 8BitDo Ultimate Wireless Joystick Module Replacement: paso 4, imagen 3 de 3
      • The ribbon cable is secured with a locking tab connector.
      • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
      Pregunta a FixBot
      Agregar Comentario
    1. 8BitDo Ultimate Wireless Joystick Module Replacement, Joystick's Module: paso 5, imagen 1 de 1
      • Grip each analog stick cap firmly and pull straight up to remove them.
      Pregunta a FixBot
      Agregar Comentario
    2. 8BitDo Ultimate Wireless Joystick Module Replacement: paso 6, imagen 1 de 2 8BitDo Ultimate Wireless Joystick Module Replacement: paso 6, imagen 2 de 2
      • Remove the three 5 mm Phillips #00 screws securing the midframe to the back shell, then lift it straight out.
      Pregunta a FixBot
      Agregar Comentario
    3. 8BitDo Ultimate Wireless Joystick Module Replacement: paso 7, imagen 1 de 2 8BitDo Ultimate Wireless Joystick Module Replacement: paso 7, imagen 2 de 2
      • Turn to the backside of the circuit board for clear access to the solder joints.
      • Desolder all of the outlined solder joints.
      • Refer to the following solder guide if necessary: How To Solder and Desolder Connections
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Garcia
Miembro Desde 04/03/26
473 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 Miembro de UMass Dartmouth, Team 1-3, Biswokarma Spring 2026
UMASSD-BISWOKARMA-S26S1G3
Miembros de 5
59 Guías creadas
1Guía Comentario
can you provide part numbers for the joystick modules?
Harold Timmis - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 60
Ultimos 30 días: 283
Todo El Tiempo: 647
