Saltar al contenido principal
No esta en la lista
Este wiki no aparecerá en los resultados de búsqueda, pero todavía puede ser visto por cualquier persona!
Traducción del Manifiesto de Reparación, neerlandés
Hacer el texto más claro y fluido
Esta es una traducción del Manifiesto de Reparación
6 comentarios
Nice attempt, but it looked a bit too much like a first draft. Did a substantial rewrite.
Ulanthe - Contestar Compartir
Thanks! I have no idea what I put in there, glad you do ;)
Chris Cline - Contestar Compartir
The line "Repareren bevorderd" needs to be "Repareren bevordert".
"Beschikbare reserveonderdelen AAN redelijke prijzen" is pretty much Flemmish and not generic Dutch. AAN should be replaced by "voor" or "met"
The line "Repareren leert technische vaardigheden" will sound better if it says "Repareren brengt technische vaardigheden". Leren is the consuming part connected to teaching, and not well suited as the knowledge transferring activity in this case.
Blkksss - Contestar Compartir
Existing translation was already quite good. I tried to improve a bit here and there. Thanks to all that did work on this before!
Marius Opsomer - Contestar Compartir
"zelf om het even welk onderdeel te vervangen" <> "to replace any & all consumables ourselves" , because "onderdeel" means "part".
"consumables" can better be translated as "verbruiksonderdelen" which means "consumable parts" or "verbruiksartikelen" which means "consumable articles".
Paul - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 2,589
