Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Lasergrip won't turn on
No matter what you do, you can't get your Lasergrip to turn on.
Drained/bad battery
If your Lasergrip won't turn on, .... you may simply have a drained battery, so it should be replaced. If the issue continues, then there might be an issue with the connector to the battery. If so, that needs a replacement instead. Here is a guide to replacing the battery and here is a guide to replacing the battery connector.
Bad display
It is possible that it appears nothing is happening because the display is bad or there is something wrong with the wires. If the former, the display must be replaced. If there are problems with the wires, then that also needs a replacement. Here is a guide to replacing the screen.
Bad motherboard
The motherboard simply needs a replacement. Here is a guide to replacing the motherboard.
Lasergrip won't shoot the laser
When pressing the trigger, the laser is not showing up.
Malfunctioning trigger
There might be a bad contact of the sensor inside the trigger. Check and see if the spring behind the trigger is positioned correctly. If it's not, that might be source of the issue. Here is a guide to replacing/repairing the trigger.
Laser turned off or malfunctioning
There is a button on the face of the Lasergrip that turns the laser on and off. The laser might simply be turned off or malfunctioning. Here is a guide to replacing the laser.
The buttons are not responsive
No matter what you do, you can't get your Lasergrip to respond.
Buttons are loose or broken
The buttons might be misplaced, so it won't have the right contact. Check to see if the buttons are touching the sensors correctly. If they are but the device is still not responsive, then the issue are the sensors. Here is a guide to repairing or replacing the buttons.
The screen doesn't work
You can see the laser, but the screen is off.
Broken screen
If the screen is simply broken, then it needs a replacement. Here is a guide to replacing the screen.
Motherboard issue
Either the motherboard is broken or it has bad contacts with the screen. If the former, the motherboard needs a replacement. Here is a guide to replacing the motherboard.
The temperature doesn't seem right from the device
For whatever reason, the temperature seems to be off or different
Sensor isn't working right
The sensor needs to be working correctly for it to read the temperatures correctly. If it isn't, then the sensor might be broken. The motherboard might be faulty if that's the case. Here is the repair guide for the sensor.
Temperature is not on the right mode
Make sure the temperature you want is set on the right mode, Fahrenheit and Celsius. There is a button where you can change the mode. If for some reason you are unable to change it, then the button is faulty. Refer to the faulty buttons troubleshooting topic.
4 comentarios
What is the AL reading mean
Steve Riddle - Contestar
What does “HOLD” reading mean?
Zesko - Contestar
what does HOLD mean on screen
Patrick O'Shaughnessy -
My screen shows HOLD in the upper left corner. What is that for and how to delete from screen
Patrick O'Shaughnessy - Contestar
