Saltar al contenido principal
Lasergrip 1080 Sensor Replacement
Qué necesitas
  1. Lasergrip 1080 Sensor Replacement, Battery: paso 1, imagen 1 de 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Lasergrip 1080 Sensor Replacement: paso 2, imagen 1 de 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Lasergrip 1080 Sensor Replacement: paso 3, imagen 1 de 2 Lasergrip 1080 Sensor Replacement: paso 3, imagen 2 de 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Lasergrip 1080 Sensor Replacement, Buttons: paso 4, imagen 1 de 2 Lasergrip 1080 Sensor Replacement, Buttons: paso 4, imagen 2 de 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Lasergrip 1080 Sensor Replacement: paso 5, imagen 1 de 2 Lasergrip 1080 Sensor Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Lasergrip 1080 Sensor Replacement: paso 6, imagen 1 de 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Lasergrip 1080 Sensor Replacement: paso 7, imagen 1 de 2 Lasergrip 1080 Sensor Replacement: paso 7, imagen 2 de 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Lasergrip 1080 Sensor Replacement: paso 8, imagen 1 de 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Lasergrip 1080 Sensor Replacement, Etekcity Lasergrip 1080 Trigger Replacement: paso 9, imagen 1 de 2 Lasergrip 1080 Sensor Replacement, Etekcity Lasergrip 1080 Trigger Replacement: paso 9, imagen 2 de 2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Lasergrip 1080 Sensor Replacement, Sensor: paso 10, imagen 1 de 1
    • Pull the motherboard out of its slot in the device.
  11. Lasergrip 1080 Sensor Replacement: paso 11, imagen 1 de 1
    • Using a soldering iron, melt the solder that holds the wires for the sensor to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
Conclusión
Una persona más ha completado esta guía.
Carlos Lewis
Miembro Desde 08/27/15
162 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 5-1, Blackwell Fall 2015 Miembro de USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,532
