Saltar al contenido principal
Etekcity Lasergrip 1080 Battery Connector Replacement
Qué necesitas
  1. Etekcity Lasergrip 1080 Battery Connector Replacement, Battery: paso 1, imagen 1 de 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Battery Connector Replacement: paso 2, imagen 1 de 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Battery Connector Replacement: paso 3, imagen 1 de 2 Etekcity Lasergrip 1080 Battery Connector Replacement: paso 3, imagen 2 de 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Battery Connector Replacement, Buttons: paso 4, imagen 1 de 2 Etekcity Lasergrip 1080 Battery Connector Replacement, Buttons: paso 4, imagen 2 de 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Battery Connector Replacement: paso 5, imagen 1 de 2 Etekcity Lasergrip 1080 Battery Connector Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Battery Connector Replacement: paso 6, imagen 1 de 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Battery Connector Replacement: paso 7, imagen 1 de 2 Etekcity Lasergrip 1080 Battery Connector Replacement: paso 7, imagen 2 de 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Battery Connector Replacement: paso 8, imagen 1 de 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Battery Connector Replacement, Etekcity Lasergrip 1080 Trigger Replacement: paso 9, imagen 1 de 2 Etekcity Lasergrip 1080 Battery Connector Replacement, Etekcity Lasergrip 1080 Trigger Replacement: paso 9, imagen 2 de 2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Battery Connector Replacement, Battery Connector: paso 10, imagen 1 de 1
    • Pull the motherboard out of its slot in the device.
  11. Etekcity Lasergrip 1080 Battery Connector Replacement: paso 11, imagen 1 de 1
    • Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
Conclusión
Equipo
USF Tampa, Team 5-1, Blackwell Fall 2015 Miembro de USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 727
