Saltar al contenido principal
Etekcity Lasergrip 1080 Button Replacement
Qué necesitas
  1. Etekcity Lasergrip 1080 Button Replacement, Battery: paso 1, imagen 1 de 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Button Replacement: paso 2, imagen 1 de 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Button Replacement: paso 3, imagen 1 de 2 Etekcity Lasergrip 1080 Button Replacement: paso 3, imagen 2 de 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Button Replacement, Buttons: paso 4, imagen 1 de 2 Etekcity Lasergrip 1080 Button Replacement, Buttons: paso 4, imagen 2 de 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Button Replacement: paso 5, imagen 1 de 2 Etekcity Lasergrip 1080 Button Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Button Replacement: paso 6, imagen 1 de 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Button Replacement: paso 7, imagen 1 de 2 Etekcity Lasergrip 1080 Button Replacement: paso 7, imagen 2 de 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Button Replacement: paso 8, imagen 1 de 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
Conclusión
Equipo
USF Tampa, Team 5-1, Blackwell Fall 2015 Miembro de USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 479
