Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Recurring Black Screen
The laptop screen is black and doesn't appear to be on, or the laptop appears to be on but the screen is blank.
Update BIOS
Download this file. Copy this file to a flash drive and insert into the USB port. Simultaneously press the Fn key, Esc key and power button until the power light comes on. The light should then start to blink. Let the laptop run from 1-7 minutes and the problem should be fixed.
Replace Screen
Replace the screen using this guide.
Replace The Hard Drive
Consider replacing the hard drive with a new one using this guide.
Random Restarting
The laptop will power down in the middle of use. The laptop may or may not then turn back on.
Battery Is Not Charged Completely
Plug the charging cord into the laptop charging port and then plug into the wall. Allow the laptop to charge for a few hours until it's fully charged.
Fan Is Not Working Properly
Clean out the fan using this guide.
Replace The Battery
Consider replacing the battery using this guide.
Overheating And Shut Down
The laptop will get really hot and then shut down.
Dust In The Fan
Loud Grinding Noise
There is a loud grinding or rattling noise even if the laptop appears to be functioning properly.
Dust In The Fan
Battery Life Is Short
The laptop appears to die quickly even after battery is charged fully.
Battery Needs Replacing
Replace the battery using this guide.
Laptop Is Overheated
Consider cleaning out the fan using this guide.
0 comentarios
