Saltar al contenido principal
Acer Aspire One AO756-2623 Fan Replacement
Qué necesitas
  1. Acer Aspire One AO756-2623 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Fan Replacement: paso 2, imagen 1 de 1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Fan Replacement: paso 3, imagen 1 de 3 Acer Aspire One AO756-2623 Fan Replacement: paso 3, imagen 2 de 3 Acer Aspire One AO756-2623 Fan Replacement: paso 3, imagen 3 de 3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Fan Replacement, Back Cover: paso 4, imagen 1 de 1
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Fan Replacement: paso 5, imagen 1 de 2 Acer Aspire One AO756-2623 Fan Replacement: paso 5, imagen 2 de 2
    • Slide the back plate downward to remove it from the laptop.
  6. Acer Aspire One AO756-2623 Fan Replacement, Keyboard: paso 6, imagen 1 de 1
    • Locate the eighteen 6 mm Phillips screws that are required to remove the keyboard.
    • Remove all screws using a Phillips #0 screwdriver.
  7. Acer Aspire One AO756-2623 Fan Replacement: paso 7, imagen 1 de 1
    • Orient the laptop to where the open screen is facing towards you.
    • Slide the spuldger into the indicated crease.
    • Firmly slide spudger all the way around the laptop to pry the keyboard away from the bottom of the laptop.
    • Loud cracking noises will be heard during this step.
  8. Acer Aspire One AO756-2623 Fan Replacement: paso 8, imagen 1 de 3 Acer Aspire One AO756-2623 Fan Replacement: paso 8, imagen 2 de 3 Acer Aspire One AO756-2623 Fan Replacement: paso 8, imagen 3 de 3
    • Remove the green dotted ribbon cable by sliding it straight out of the clamp holding it in using a plastic spudger.
    • Locate the two tabs that are holding the larger black ribbon cable in place.
    • Remove the larger black ribbon cable by pressing in the tabs and sliding it straight out of the clamp holding it in using a plastic spudger.
    • To remove the keyboard, lift the keyboard straight away from the rest of the laptop.
  9. Acer Aspire One AO756-2623 Fan Replacement: paso 9, imagen 1 de 3 Acer Aspire One AO756-2623 Fan Replacement: paso 9, imagen 2 de 3 Acer Aspire One AO756-2623 Fan Replacement: paso 9, imagen 3 de 3
    • Locate the ten 6 mm Phillips screws that connect the keyboard to the rest of the laptop and remove them with a Phillips #0 Screwdriver.
    • Locate the four 6 mm Phillips screws hidden beneath black tape by lifting up the black tape and remove them with a Phillips #0 Screwdriver.
    • To remove keyboard from the rest of the laptop, pull keyboard straight up.
  10. Acer Aspire One AO756-2623 Fan Replacement, Fan: paso 10, imagen 1 de 1
    • Orient laptop with open screen facing you.
    • Peel back black tape.
  11. Acer Aspire One AO756-2623 Fan Replacement: paso 11, imagen 1 de 2 Acer Aspire One AO756-2623 Fan Replacement: paso 11, imagen 2 de 2
    • Orient the laptop to where the bottom of the laptop is facing upwards.
    • Locate the port that connects the fan to the laptop.
    • Use a nylon spudger to firmly pull out the cable from the port.
    • Pull the fan straight out to remove it from the rest of the laptop.
Conclusión
Una persona más ha completado esta guía.
Davis Adams
Miembro Desde 03/20/16
465 Reputación
3 Guías creadas
Equipo
Clemson, Team 7-1, Benson Spring 2016 Miembro de Clemson, Team 7-1, Benson Spring 2016
CLEM-BENSON-S16S7G1
4 Miembros
14 Guías creadas
Un comentario
don’t know if i’ll tackle this. have had mine at least 5 yrs. heating up and shutting off now. maybe i’ll try it along with new heat sink paste and if that helps give it to my son, as i just bought a new Acer. thanks for the clear instructions.
misciagna - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 2,336
