Saltar al contenido principal
Acer Aspire One AO756-2623 LCD Sceen Replacement
Qué necesitas
  1. Acer Aspire One AO756-2623 LCD Sceen Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 2, imagen 1 de 1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 3, imagen 1 de 3 Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 3, imagen 2 de 3 Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 3, imagen 3 de 3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 LCD Sceen Replacement, LCD Sceen: paso 4, imagen 1 de 1
    • Orient the laptop as shown in the picture with the open screen facing toward you.
  5. Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 5, imagen 1 de 3 Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 5, imagen 2 de 3 Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 5, imagen 3 de 3
    • Insert the spudger into the indicated crease.
    • Firmly slide spudger around the edge of the entire laptop to remove the front plate of the screen.
    • Loud cracking noises from the plastic tabs separating may occur, do not worry, they are to be expected.
  6. Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 6, imagen 1 de 3 Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 6, imagen 2 de 3 Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 6, imagen 3 de 3
    • Identify the four 6 mm Phillips screws that are necessary to remove the LCD screen.
    • Remove all four screws using a Phillips #0 Screwdriver.
    • Pull away the LCD screen from the back cover of the laptop without ripping the ribbon cable connecting it to the bottom of the laptop.
  7. Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 7, imagen 1 de 3 Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 7, imagen 2 de 3 Acer Aspire One AO756-2623 LCD Sceen Replacement: paso 7, imagen 3 de 3
    • Remove the tape covering the port connecting the screen to the bottom of the laptop.
    • To remove the LCD screen, gently pull the cable straight out of the screen.
    • In the first and second photos, the screen is lying face down on the keyboard.
Conclusión
3 personas más completaron esta guía.
Davis Adams
Miembro Desde 03/20/16
465 Reputación
3 Guías creadas
Equipo
Clemson, Team 7-1, Benson Spring 2016 Miembro de Clemson, Team 7-1, Benson Spring 2016
CLEM-BENSON-S16S7G1
4 Miembros
14 Guías creadas
Un comentario
Spot on! Perfect tutorial thank-you very much!
Sonia Green - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 1,019
