Saltar al contenido principal
Acer Aspire One AO756-2623 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire One AO756-2623 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Hard Drive Replacement: paso 3, imagen 1 de 3 Acer Aspire One AO756-2623 Hard Drive Replacement: paso 3, imagen 2 de 3 Acer Aspire One AO756-2623 Hard Drive Replacement: paso 3, imagen 3 de 3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Hard Drive Replacement, Back Cover: paso 4, imagen 1 de 1
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Hard Drive Replacement: paso 5, imagen 1 de 2 Acer Aspire One AO756-2623 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Slide the back plate downward to remove it from the laptop.
  6. Acer Aspire One AO756-2623 Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 1
    • Locate the four 6 mm Phillips screws pictured necessary to remove the hard drive.
    • Remove all four of the screws using a Phillips #0 Screwdriver.
  7. Acer Aspire One AO756-2623 Hard Drive Replacement: paso 7, imagen 1 de 2 Acer Aspire One AO756-2623 Hard Drive Replacement: paso 7, imagen 2 de 2
    • Locate the two tabs that keep the hard drive ribbon cable connected to the laptop.
    • Using a spudger, gently push in the indicated tabs.
    • While holding down the tabs, slide the ribbon cable to the left to remove it from the laptop.
  8. Acer Aspire One AO756-2623 Hard Drive Replacement: paso 8, imagen 1 de 1
    • Remove the hard drive by pulling it straight out.
Conclusión
3 personas más completaron esta guía.
Colin Rodwell
Miembro Desde 03/21/16
373 Reputación
3 Guías creadas
Equipo
Clemson, Team 7-1, Benson Spring 2016 Miembro de Clemson, Team 7-1, Benson Spring 2016
CLEM-BENSON-S16S7G1
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 2,244
