Saltar al contenido principal
« Volver a todos los relatos
Resurrecting an Old Workhorse
Becky Hansmeyer -
iPod 4th Generation or Photo
Imagen del relato
  • Imagen 1
  • Imagen 2
iPod 4th Generation or Photo Battery Replacement
15 Minuto - 1 Hora
Moderate
Mi Problema
My old iPod 4th Gen/Photo couldn't hold a charge anymore, and it seemed a shame to abandon it when new batteries are so cheap. At 60GB, it can still hold my entire music library.
Mi Solución
It was fairly difficult to pry the iPod apart; I broke one small plastic iPod opening tool in the process and ended up wedging a credit card in the opening to keep it from snapping shut while I worked my way around the side of it. It was also really difficult to get the old battery disconnected...ended up using needle nose pliers to wiggle the connector back and forth. Even with those struggles, the replacement took less than 10 minutes.
Mi Consejo
Discovered that the casing can withstand a fair amount of brute force! Also, you may need to get creative with the tools you use to pry it open and remove the battery.
Imagen de iPod 4G/Photo Battery
$13.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 17
Todo El Tiempo: 68
