Saltar al contenido principal
« Volver a todos los relatos
2011 iPhone 4s First-Time Battery Replacement
Leandro de la Rosa -
iPhone 4S
Imagen del relato
iPhone 4S Battery Replacement
3 Hora
Moderate
Mi Problema
The battery's lifespan has severely degraded after 7 years. The indicator gets stuck on 1% for a long time.
Mi Solución
It went well with the exception of the removal of the 1.7 mm Phillips screw by the battery connector. The reason it took my battery replacement process 3 hours is that I stripped the aforementioned screw. The included iFixit screwdriver's Phillips screw attachment for reason didn't go well with the 1.7 mm screw. After I miraculously removed the stripped screw, everything else went without a hitch.
Mi Consejo
Don't strip any screws. If you think you are careful during the unscrewing process, you should probably be a little bit more careful.
Imagen de iPhone 4S Battery
iPhone 4S Battery
$18.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 246
