Saltar al contenido principal
« Volver a todos los relatos
iPod mini replacement gone awry
Colin Szechy -
iPod Mini
Imagen del relato
  • Imagen 1
  • Imagen 2
iPod Mini Battery Replacement
30 Minuto
Moderate
Mi Problema
My iPod mIni's battery was dying, and I wanted to replace it to get more life out of it.
Mi Solución
Not well. The two screwdrivers (#00 Phillips and a flathead) look to be decent. It was a little hard prying out the white tabs, but after that, disassembly was easy.
THE BATTERY THEY GIVE YOU IS LARGER THEN THE ORIGINAL. That's worked out okay for most of the repair stories I've seen, but not this one. When I went to put the entire assembly back in, I wasn't careful enough and the battery was struggling to fit... resulting in a component giving in. Namely, I cracked my screen. Don't know how to repair that one.
The bit around the crack still works at least... bleh.
Mi Consejo
Be careful about putting the whole assembly back in
1 comentario
Hope it goes well:)
HolishXXX - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 132
