Saltar al contenido principal
« Volver a todos los relatos
Easy battery replacement
William Neuson -
MacBook Pro 15" Unibody Early 2011
Imagen del relato
MacBook Pro 15" Unibody Early 2011 Battery Replacement
20 Minuto
Moderate
Mi Problema
My MacBook battery began to fail and expanded to the point of temporarily deforming the aluminum near the trackpad.
Mi Solución
Using the iFixit Pro Tech Toolkit, I followed the instructions in the step-by-step guide. The battery charged in a few hours and proceeded to work fine.
Mi Consejo
In the event that the battery swells, remove the screws from the case closest to the failing section of the battery. Use a flat tool to carefully help the battery case out of the machine if the swelling is enough to deform the case.
Imagen de MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery
$69.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 122
