Saltar al contenido principal
« Volver a todos los relatos
Replaced iPad Air Front Panel
maliawaddell -
iPad Air Wi-Fi
Imagen del relato
  • Imagen 1
  • Imagen 2
  • Imagen 3
iPad Air Wi-Fi Front Panel Assembly Replacement
2 Hora
Difficult
Mi Problema
My iPad had the ghost touching problem, where it just started freaking out and opening apps without being touched. My research pointed to a digitizer problem. I also had a small cracked screen area.
Mi Solución
I had mixed results. Eventually I fixed it. Getting the original screen off with all that adhesive was no joke. I also cracked my replacement screen trying to install the home button and had to order another. The home button still doesn't respond as well as the original. But I have a functioning iPad again! So I'll consider it a win.
Mi Consejo
Definitely order the replacement assy that has the adhesive and home button pre-installed. A razor blade and a blow dryer were my main tools used to remove the screen.
Imagen de iPad Air Screen Digitizer
$29.99
1 comentario
Sounds tricky, but glad you worked it out!
Cynthia Replogle - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 166
