Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
Lanzado en septiembre de 2001 con el número de modelo C21-0111. Este objetivo sustituyó al Canon EF 70-200 mm f/2,8L USM, con la incorporación de un nuevo sistema de estabilización de imagen (IS) y un diseño óptico mejorado.
How to remove interior fungus...etc.
I'm looking for a step by step disassembly, cleaning (fungus and stuff)and reassembly. Anybody?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Hey!
This is the same reason I took apart my 90-300mm lens, and I did end up cleaning all the gunk out. BUT - I would highly recommend going to a professional with this one, because this is a much more complicated lens. If you really do want to take it apart, I would do a quick Google search on disassembly, and then take it apart and clean it carefully with a microfiber cloth. Make sure to document which screws go where, and take pictures of each step and what you did. Good luck!
- de Compartir
Agregar un comentario
1 Respuesta
For fungus inside that lens, I’d be careful about a full DIY teardown because the optical groups need to go back in exactly the same orientation and spacing.
A safer starting point is to remove the rear mount and inspect where the fungus is located. If it’s on an accessible element, cleaning may be possible, but fungus between sealed optical groups usually calls for a lens technician.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
kulajon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 44
Todo El Tiempo: 67
