Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Makita XDT08 es una llave de impacto inalámbrica diseñada para uso profesional, que cuenta con un motor sin cepillo y compatibilidad con baterías de iones de litio LXT de 18 V. Con unas dimensiones de 5-7/8" x 3-1/4" x 9-1/8" y un portapuntas hexagonal de 1/4", ofrece un alto torque y velocidad para diversas tareas de fijación y atornillado.
cracking the driver case
I need to replace the switch. I have all of the screws out but the yellow plastic peice at the bottom is preventing me from cracking the case open. I have pryed on it with a screw driver and it won't separate. I don't want to break it. How do I split this open without damage.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Yeah, I wouldn’t keep hammering that yellow piece with a screwdriver. On the XDT08, the housing is held together by eight 3×16 screws, and the parts diagram shows the housing as a two-piece housing set. The switch itself is part 650689-0.
That yellow piece you’re seeing at the bottom is probably the battery terminal/support area catching on the housing. When you separate the halves, work around the housing seam with a thin plastic pry tool and gently work the halves apart rather than prying directly against the yellow plastic. The same basic Makita housing procedure on these impact drivers is to separate the two shell halves carefully while keeping the yellow battery-terminal piece seated in the lower housing. Once you get a small gap, go around the perimeter and release the shell little by little. Don't force one spot. There may also be wiring and the controller sitting in the housing, so I'd rather spend five minutes working the seam than crack a $30-ish housing or pull a wire loose.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Brian Taylor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 10
Todo El Tiempo: 10
