Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Guías de reparación, desmontaje e información para la solución de problemas de los mandos Joy-Con 2 de la Nintendo Switch 2.
ZL Button Spring not working
I am trying to reassemble the left Joycon 2, and when I want to attach the ZL button, it feels like the spring is not doing its work. The ZL button is really steady and almost rubbing the button, so with a little touch it will press it.
Imagen
Imagen
Update (09/28/26)
Hello,
I was changing the covers. At the end I found the issue. The flex was not seating well on the support. From the top it looked like it was in the support, but I saw it sideways and it was not. This is why the ZL button was almost touching the button.
Imagen
Imagen
Thank you for reaching out!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Hi!
Glad that you figured it out :)! Have a great day!
- de Compartir
Thank you! I was about to just accept I busted my controller until I found this.
- de Compartir
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi!
Please follow this to step 13: Reemplazo del joystick Joy-Con 2 (izquierdo)
Could you show us how the spring look like?
What is the reason you opened it? Is another shell used or is this a cover that you have put on?
I know that some shells do not fit completely and could cause this as well.
Thanks!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
David Sandoval Galiana estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 27
Ultimos 30 días: 101
Todo El Tiempo: 159
