Especificaciones del Realme C53
- Pantalla: LCD IPS de 6.74 pulgadas, resolución HD+, frecuencia de refresco de 90Hz
- Procesador: UNISOC Tiger T612, ocho núcleos (hasta 1.82GHz)
- RAM/Almacenamiento: 6GB de RAM + 128GB de almacenamiento (ampliable hasta 2TB)
- Cámaras:
- Trasera: 50MP + lente de IA
- Frontal: cámara frontal de 8MP
- Batería: 5,000mAh con carga rápida SUPERVOOC de 33W (USB-C)
- Sistema operativo: Android 13 con Realme UI T Edition
- Otras características: Lector de huellas lateral, Wi-Fi de doble banda, 4G LTE, diseño ultradelgado de 7.49mm
Desplázate por este tema para encontrar el lugar apropiado para este comentario. Luego haz clic en "Añadir comentario a esta publicación" para moverlo.
1 comentario:
When you say you have an IC problem, can you be more specific? There are dozens if ICs inside a phone; which one do you suspect and what makes you think that?
You seem to indicate it's related to the camera; what kind of problem are you having with it? What is it doing or not doing? The better you can describe your issue, the better chance we have of being able to help. The information you've given us so far isn't enough for us to go on to figure out what's going on with your phone..
- de Jerry Wheeler Compartir
