Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Skullcandy Air Raid es un altavoz Bluetooth portátil inalámbrico lanzado el 15 de noviembre de 2013 que transmite música desde cualquier dispositivo con Bluetooth habilitado.
Rained on while charging
I was charging it outside and it rained lightly for maybe 30 minutes or so and now the speaker won't turn on at all how can I fix itI was charging it outside and it rained lightly for maybe 30 minutes or so and now the speaker won't turn on at all how can I fix it
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Rain can short circuit electronics, starting with water entry into the charging port. Whether this caused the battery to drain is one possible issue. Disassembly should be performed to wipe off remaining water, allow inspection of wiring for corrosion and damage to electronics. Tissues, cotton swabs and isopropyl alcohol can help with clean up. If you are successful in disassembly, leave parts exposed to dry out. Placed in a tray on top of a gas stove with its pilot light supplying gentle heat, in a gas oven with similar pilot light for heat or out in the sun. Warmth over several hours will help evaporate remaining moisture. Reassemble and try recharging. The battery may recharge and allow operation. Battery specs are printed on labeling. Click on the Guides tab in the upper right to open a new page and click on Battery Replacement to reveal disassembly procedures or below. Sustitución de la batería del Skullcandy Air Raid. Hopefully, damage didn't occur, the battery recharges, and you restored your Skullcandy Air Raid back to full function.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Carlos Cordova estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 44
