El Chrysler 300 es un automóvil de lujo de tamaño completo con motor delantero y tracción trasera, fabricado y comercializado por Chrysler como sedán de cuatro puertas y familiar.
Desplázate por este tema para encontrar el lugar apropiado para este comentario. Luego haz clic en "Añadir comentario a esta publicación" para moverlo.
2 comentarios:
@testemail what makes you think that you have an issue with your ABS unit? Have you got your vehicle scanned? Any error codes? What are the issues with you brakes? What exact year is your 300?
In addition to oldturkey03's question, if the abs indicator turned on and remained on, there's an error code but decoded by readers/scantools Autozone, Advanced Auto, transmission, collision and repair shops have. Not generic low cost readers. If the abs indicator cycles on and off with other indicators when turning on ignition, abs is operating correctly (power on self tests including all wiring to wheel speed sensors). Abs errors are usually C type codes.
- de oldturkey03
- de F Dryer
