L3 doesn't work
L3 doesn't pressing don't work
Es esta una buena pregunta?
Does the analog stick still make the click when you press it?
If it does, cleaning the joystick with contact cleaner may fix it.
If not the button is likely busted and the joystick module will need to be replaced. This does require a good amount of soldering skills and tools, but is doable at home with some patience!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 64
