Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
A1708/EMC 3164 — Lanzado en junio de 2017, este MacBook Pro de gama de entrada conserva sus teclas de función tradicionales (a diferencia de la Touch Bar OLED).
MacBook battery cable Problem
Hello, I have a 2017 MacBook Pro 13-inch. I recently replaced the screen, and after the repair, the laptop would not power on unless it was connected to a high-wattage charger. It does turn on with the AC adapter, but there is an “X” over the battery icon, and if I unplug the charger, the laptop immediately shuts off.
I suspect the issue may be the battery ribbon cable, which I’ve already ordered, but I wanted to see if anyone else has experienced this or knows what the problem might be.
Thanks in advance!
Imagen
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Looking at the picture (left side connection) the cable isn't pushed into the connector and latched down.
- de
Agregar un comentario
1 Respuesta
Double check the ribbon cables ZIF connectors as often the compression latches are not properly set so the connection is not making good contact. Review the steps 11 & 12 in the Reemplazo de la batería de MacBook Pro 13" Function Keys 2017 jump between two images of Step 11 note the lifting of the latch. Make sure the latch is reset pressing it down once the ribbon is squarely in place on both ends.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Frank I estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 21
Ultimos 30 días: 24
Todo El Tiempo: 150
