Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Asus Zenbook 13 UX363EA salió al mercado a finales de 2020. Está equipado con procesadores Intel Core de 11ª generación y gráficos Iris Xe. Cuenta con dos puertos Thunderbolt 4 y un puerto HDMI de tamaño completo, pero carece de un conector para auriculares de 3.5 mm; la autonomía de la batería se anuncia como de hasta 16 horas.
Guide for keyboard replacement
If anyone has a guide for replacing the keyboard in an Asus UX363EA model Zenbook I would be grateful. A pointer to an online copy would be as good.
Failing that, any advice or cautions could be useful. I have the new keyboard, a comprehensive toolkit and 50 years of experience in electronics repair but these clever buggers keep coming up with new and exciting ways of doing things.
Regards, Geoff M
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
@geoffmorris big job. The keyboard is actually considered part of the top case. It is riveted to the case with "oodles" of rivets.
Imagen
You would have to drill those out and then use small screws and plenty of adhesive to replace the keyboard. It's a PITA and if not done right leads to a "wobbly" keyboard etc. You may consider replacing the complete top case. Use something like this ASUS UX363E SERIES REPAIR MANUAL to work on your Zenbook
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Geoff Morris estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 40
Todo El Tiempo: 292
