Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Guías de reparación, desmontaje e información sobre Resolución de Problemas para el mouse inalámbrico portátil Logitech MX Anywhere 3S. Anunciado en mayo de 2023 e identificado con los números de parte 910-006925, 910-006926, 910-006927 o 910-006928, según el color. Sucesor del MX Anywhere 3.
Left button not working
The left button intermittently works and has been getting progressively worse over time. Should I follow the disassembly steps as described to replace the battery and try and clean the buttons with compressed air?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @mcfb, if the Logitech MX Anywhere 3S is still under warranty, I recommend sending it in for repair. Based on my experience, once the warranty has expired the usual fix is replacing the microswitch. The part commonly used is an Omron D2FC-F-7N or similar, which requires desoldering the old switch and soldering in the new one.
Fue útil esta respuesta?
Puntuación 3
4 comentarios:
Thanks @augustine, I'm chasing warranty - I'll see how that goes first. Thanks for the help.
- de Compartir
Is this a common problem with this model?
- de Compartir
I have the same problem with left click, i'm going to try to repair the button. (Tape was not the issue, it was 100% the button malfunctioning)
- de Compartir
This can't be true, those switches are substantially larger than the ones present in the MX Anywhere 3S
- de Compartir
Añadir tu respuesta
mcfb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 41
Ultimos 30 días: 187
Todo El Tiempo: 1,295
