Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
I keep on getting error code 00
why do i keepon getting error code 00 on my asus mother board
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
I'd like to know where you encountered the 00 error code?
Is it displayed on the motherboard's PCI/PCIE slots, or on the DDR3/DDR4/DDR5 diagnostic card?
- de Compartir
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi!
Please provide your exact motherboard model along with the rest of your system! Also, do you have any signs of life, symptoms or anything happening with your system? Does you get an output, or anything?
Have you just built this PC, or did this come suddenly in a known working system? Have you had any other problems or symptoms recently?
By some quick searching, I found this guide on another forum, please read and go through it and then respond with how it went.
Some additional stuff, the guide above mentions resetting BIOS, to enter bios see your motherboard manual, usually the F2 or DEL key during boot. You may have an option to reset or boot from a back-up bios depending on your motherboard model, please check with your motherboard manual for that, and/or post your motherboard model and we can try to help you.
Some general tips that you should try:
  • Try to test your ram and ram sockets.
    • Take out all your ram, and then put one stick in the DIMM_A1 socket (see your motherboard manual for this) and try booting your system.
    • If this does not work. Try another stick of ram in the same slot and try booting your system.
    • If this does not work. Repeat both prior steps in the DIMM_B1 socket.
    • If this does not work. Plug in all your ram sticks in accordance with your motherboard manual.
  • Try unplugging EVERYTHING in your system (yes, CPU too!) and then re-plug all of it. Make this for both components, as well as cables! Also make sure that you have not missed plugging in a power cable anywhere.
Please respond after you've done all of this and we will see how we can further assist you.
Good luck,
Cheers
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
@meekvixen you got two links to the same site :)
- de Compartir
@oldturkey03 Hmmm... that's funny. Seems the formatting separated the link into two? (It were only supposed to be a single link)
Thanks for keeping tabs on me (:
- de Compartir
Añadir tu respuesta
yusuf estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 30
Todo El Tiempo: 363
