Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Canon EOS 5D Mark II es una cámara réflex digital de un solo lente (DSLR) CMOS de 21.1 megapíxeles con fotograma completo y capacidad de grabación de video.
How to fix error 06
self-cleaning sensor unit malfunction
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Error 06indicates a malfunction with the Self-Cleaning Sensor Unit, meaning the automatic sensor cleaning process failed, often due to a stuck sensor or mechanical issue with the cleaning mechanism. Basic troubleshooting involves turning the camera off and on, removing/reinserting the battery, and sometimes gently tapping the camera, but if the error persists, it likely needs servicing by a professional Canon repair center.
Troubleshooting Steps (Try in Order):
  1. Power Cycle: Turn the camera's power switch to OFF, wait a few seconds, then turn it back ON.
  2. Battery Reset: Turn the camera off, remove the battery and memory card, wait a minute, then reinsert them and power on.
  3. Gently Tap: With the camera off, try gently tapping the camera body (not too hard) to potentially dislodge the sensor unit.
  4. Disable Automatic Cleaning: If the camera turns on, try disabling the automatic sensor cleaning in the menu to prevent it from triggering the error.
  5. Check Lens Contacts: While less common for Error 06, ensure lens and camera contacts are clean, as communication issues can sometimes cause general errors.
This video demonstrates the basic troubleshooting steps for a Canon DSLR camera:
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Note that no official Canon repair center will repair the camera as the service life of the Canon EOS 5D Mark II has ended. Repairs can only be made by third party repair shops.
- de
Añadir tu respuesta
Muhammad Syah Levi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 48
Todo El Tiempo: 438
