Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una versión más asequible y puramente portátil de la consola de juegos Nintendo Switch, con controladores Joy-Con integrados y una pantalla un poco más pequeña. Lanzado el 20 de septiembre de 2019.
Volume up button doesn't work.
I got a new cat recently who required some training, and unfortunately, I think she urinated on my switch. The only issue I've noticed since cleaning it is that the volume up button no longer works. The volume down button works, the power button works, everything else seems fine, I just can't turn the volume up, and there's no setting in the Switch itself to adjust volume either. I have not yet tried anything to fix it because I'm quite inexperienced working on electronics myself, but if there is a way to fix it myself, I'll certainly try. The button does not appear to be stuck; it presses down and up normally, but it just doesn't do anything.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi there!
Yes, those buttons are replaceable!
Your in luck I guess :)!
You can follow this guide: Reemplazo de la pantalla de la Nintendo Switch Lite (from step 41 all the way till step 43).
So you dont need to remove the motherboard or other components!
If you have any questions, please let us know!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Kai Hayden estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 128
