Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Anunciado el 13 de octubre y lanzado el 23 de octubre, el smartphone insignia de Apple para 2020 cuenta con una pantalla OLED de 6.1", un sistema de cámara trasera de triple lente con LiDAR y 5G. Sucesor del iPhone 11 Pro.
Reattach/replace lightning connector?
Connecting lightning cable doesn’t always charge. It feels like something is loose in there. And when it doesn’t connect, a good smack of the phone downwards into my palm can do the trick. Also, the lightning cable can just kind of slip out, like it’s not catching in the receptacle.
So, what do you think is going on?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Given that the lightning connector is the hardest working part of the phone, generally being plugged and unplugged at least once a day if not more, it stands to reason if anything is going to wear out, it's going to be that plug.
Based on your description, it really sounds like your port has seen better days and should be replaced. I'm assuming here that you've tried all of the non-surgical remedies such as trying a different cable and cleaning and inspecting the port for any damage or obstructions like lint or dirt build up inside.
Unfortunately, iFixit doesn't have a guide to that repair, but the Spanish site Nadie Me Llama Gallina has just what you need. As you might guess, the site is in Spanish but does have an English language option.
Manuales / Apple iPhone 12 Pro / Load flex - Nadie Me Llama Gallina
I would definitely recommend replacing the port, which should get you fixed right up. If you want to support iFixit's repair efforts, you can purchase the part you need right here on this site.
iPhone 12/12 Pro Lightning Connector Assembly
If you're a bit more cost conscious, you can also find it on the major retailer sites like eBay, Amazon and AliExpress, plus a host of other places that specialize in phone parts.
Imagen de Replace a lightning connector assembly compatible with an iPhone 12 or 12 Pro. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-02627.
Producto
$26.99
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
kara07 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 42
Todo El Tiempo: 661
