Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Ford F-150 de 2015-2020 es la decimotercera generación de esta camioneta pickup de tamaño completo. Es conocida por su innovadora construcción de carrocería de aluminio, sus potentes opciones de motor y sus avanzadas características tecnológicas, ofreciendo un vehículo versátil y capaz tanto para el trabajo como para el uso diario.
2016 F-150 Steering Wheel Control Module and Clock Spring
So I got my truck serviced and they confirmed these are the components that are bad. Problem is they wanna charge $900, no insurance or warranty helping, and I practically live paycheck to paycheck. Is it possible to fix these myself?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
@oldturkey03 The big problem is the left side lever (wipers, turn signals, high beams) doesn't work. Additionally all the controls on the steering wheel don't work. Less concerned about those. The big issue my brother raised about doing this at home is if the control module would need to be programmed.
- de
Agregar un comentario
1 Respuesta
@hlasley "practically live paycheck to paycheck" I think we are all doing that right now. There just isn't any extra money is there. Anyhow, what are the symptoms for your failed module? Yes, It looks like it can be done as a DIY. Looking through the service manual right now but it's to big to post one here.
My biggest concern with that is always the air bag. I would hate for that thing to deploy while you work on it. Anyhow, start with videos like this one as well as for the module itself use this video
Yes, the module will have to reprogramed by using a Forscan unit. you may need to find someone that either has one of those or you will need to depend on your dealer. May still be cheaper then what they originally quoted you.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
H. Lasley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 24
Ultimos 30 días: 62
Todo El Tiempo: 560
