Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
El 13 de diciembre de 2012, se presentaron en Detroit, Michigan, durante el Salón Internacional del Automóvil de Norteamérica, la rediseñada Chevrolet Silverado 2014 y su modelo relacionado, la GMC Sierra 2014.
Power Lock Partially Functional (Driver Rear)
Whether I select the lock/unlock button from my key fob OR the button on the vehicle door, my rear door on the driver side only responds 50% of the time. While this is not a major issue, it's been happening for about a year, and it's starting to drive me crazy. I try to avoid going to the dealership whenever possible.
I'm assuming this is probably an electrical issue or shortage, but I'm not exactly sure of where to begin.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi Ben,
I ran into a similar issue with my son's 2003 Cadillac Deville. As it turns out, the problem was in the set of wires that run between the door frame and the door itself, so that's the place I'd suggest you start. Those wires get flexed every time the door is opened and closed, and as you can see from the harness on my son's car, eventually they give up.
Imagen
Yours aren't likely to be this bad, but you see what can eventually happen.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Ben estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 212
