Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación, desmontaje e información de resolución de problemas para el tercer rediseño principal de la popular PC de escritorio de formato pequeño Mac mini de Apple, lanzada en octubre de 2024. Cuenta con SoC M4 y M4 Pro y un mínimo de 16 GB de memoria unificada.
Upgrading Storage / restore step
I have a question about upgrading the storage on the new Mac Mini M4. I bought the base model. I have the 2T SSD card upgrade on the way from store.m4-ssd.com. I haven’t even turned on the mini yet. I am confident that I can switch out the SSD physically. But I am unclear about how to get the 2T SSD card to work. I don’t have an extra Mac lying around to use Apple Configurator. I do have a Surface Pro running windows. Can I restore the Mac mini from iTunes? The surface has 2 x USB-C® with USB 4.0 / Thunderbolt 4. So I would just have to download iTunes, run iTunes when I and connect the Mac mini to the surface pro, and turn on the mini in DFU mode. Do I have these steps right?
Or is the only way to do this is with another Mac?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
The required method is using the Apple macOS tool Configurator tool from a second Mac connected via a USB-C Thunderbolt compliant cable. Time to find a friend with a M series Mac who can help you out.
Reference:
Fue útil esta respuesta?
Puntuación 2
As an alternative, if you have a Linux box lying around you can build the idevicerestore project. I used the same SSD from m4-ssd.com and used the idevicerestore project to flash the drive. Some distros have the binary present but I found the the version distributed did not detect the newer M4 models. After building from source the M4 was recognized and I was able to flash.
https://github.com/libimobiledevice/idev...
Puntuación 0
1 comentario:
Sorry they won’t work here. Apple uses a serialization strategy which requires access to multiple chips within the system, similar to how the iPhone is protected.
- de
Añadir tu respuesta
Leanna Keightley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 72
Todo El Tiempo: 3,129
