How to create use bootable druve?
I need to format my laptop with bootable drive
Es esta una buena pregunta?
You'll need a disc image (.iso file) for this method. If you're installing windows, you can download one from Microsoft. Once you have that, you'll want to download a utility called "Rufus" that creates bootable USB drives from ISO files. You'll need a drive that can store at least 8gb, and it should be blank (or not contain any important files, as it will be deleted as part of the process).
Plug in your drive to the computer you'll use to create the bootable media, open Rufus, select the disc image you want to use and the target drive, and click start. Wait for it to finish. Make sure the computer you're formatting is off, install the drive on that computer, and turn it on
This next paragraph only applies if it doesn't boot into the USB when you turn it on:
Your computer probably already tries to boot from USB first, but if it doesn't, you might need to change the boot order in the bios. When the computer is booting, press whichever button it advises to enter setup. Do not change any other settings, find the menu that includes the boot order, and make sure usb is the first item on the list. Save and exit, and it should boot from the USB now.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 176
