Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
My consuming MB quickly when I opened data
My phone is consuming miga byte MB quickly when I opened data or am online
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@bolbakam not much of a hardware repair issue here. This sounds actually pretty normal since data does consume your memory (storage) rapidly. This all sounds like a software issue. Check for any Apps that run in the background. Make sure that you start your phone with the least amount of Apps working.
If it still does use the memory at a rate higher than ever, you want to try a factory reset. Before you do that, you should backup all of your files (pictures/music. contact. etc) since a reset will delete all of that.
You also need to know the email and the username/password that was used when this phone was originally set-up. If you don't have this, you will not be able to access your phone after the reset. Don't do it!
Thi all sounds like a software issue. Check for any Apps that run in the background. Make sure that you start your phone with the least amount of Apps working.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Bolbakam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 151
