Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
La Nintendo DS es la consola de juegos portátil de séptima generación de Nintendo y es la primera de su clase en todos los sistemas con tecnología y uso de doble pantalla, además de los sistemas tipo concha Game & Watch.
Audio doesn't work
Good evening, I received a Nintendo DS which works perfectly except for the audio. Before trying to change the speaker, are there any other ways to fix this? Luca
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Luca!
To be honest, I think it’s strange that the 2 speakers are dead. I don’t think it’s speaker related. You can try to swap them (as it’s still is a possibility that they are both dead). It’s very easy to replace them for the original DS (no soldering needed).
Now, it’s very possible that the speaker boards (where the speaker is connected to) are broken and need to be replaced! To give an idea, you can follow this guide: Recambio de pantalla LCD superior para Nintendo DS (till step 16).
It’s also possible that the audio IC died. But let’s try the other 2 (more easier) options first!
Please let us know how it goes!
EDIT photo DS original motherboard:
Imagen
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
Good afternoon, I removed the motherboard from the shell and I tried test it with some "GOOD" top parts that i obtained fixing others nintendo ds and I discovered that all of them do not play any sound. So I tried test them also with a headphones with jack but is the same… What should i do now? Luca
- de Compartir
Hi Luca! So, you took the motherboard from the "No sound DS" and tested it on other DS consoles and there is still no sound?
if this is the case, it probably is the Audio IC.... This one is difficult to fix.
You need soldering experience here to get it fixed.
I'll upload a photo regarding the components on the original DS motherboard, so you can decide if you want to fix it or not!
POST UPDATED.
- de Compartir
Can i find this chip in others console like DS Lite? Luca
- de Compartir
Yes! It should be on every DS motherboard. If you are in doubt, please share some pictures with us! Thanks!
- de Compartir
Añadir tu respuesta
Luca Di Renzo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 961
