Power button light not working
The light on my on/off button doesn't light up on my xbox one x gold rush edition the console starts up fine and works perfectly any ideas why the light won't work
Es esta una buena pregunta?
Hi Tom!
Most of the time it's either the PSU or the motherboard.
I would try a new PSU first! You can buy a replacement PSU and try it. If this didn't solved it, then return it and get yourself a refund.
Could also be the front circuit board. Does the Xbox power on with the controller?
I would try a new PSU first.
Fue útil esta respuesta?
Yes the console powers on with the controller
Alright, this changes it. Then it's probably the switch which is faulty. The PSU and motherboard should be fine. Please try a new front circuit board first. This will most likely solve it. This is the one you need: https://www.amazon.com/Internal-Circuit-...
The console is a xbox one x by the way
Yes, the part in the link I've sent is for the Xbox One X :)!
Thank you for the help hopefully I can fix it
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 53
Todo El Tiempo: 486
