Can I get a replacement battery for this here at Ifixit?
I noticed that on the website that there is only the early 2015 Macbook Pro battery available. Is it compatible with my model macbook Pro?
Es esta una buena pregunta?
I’m a bit confused, do you have a 13” or 15”?
Why I ask is the 2015” was introduced in Mid 2015. Either as a IG model - MacBookPro11,4 or a DG model - MacBookPro11,5
The only Early 2015 model is a 13” system MacBookPro12,1
To verify which is your system either look as the About This Mac or ir your system is not running then plug in your systems S/N into here EveryMac - Lookup
Once you know let us know! Or just click on the correct guide here which also offers the correct parts info
15” models Reemplazo de la batería de MacBook Pro 15" con Pantalla de Retina de Mediados de 2015
13” models Reemplazo de la batería de MacBook Pro 13" con Pantalla de Retina Principios de 2015
Guía
Dificultad:
Difícil
45 minutes - 2 hours
Guía
Dificultad:
Difícil
Fue útil esta respuesta?
The MacBook Pro 15" Retina (Mid 2015) Battery is what you need.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 43
