Right indicator not working
Left working right indicator not working
Es esta una buena pregunta?
@ranadebnath you are not telling us what you have already checked. Since the left side works, your blinker relay and fuse are likely fine. Most common issues for a not working indicator are a burnt-out bulb, a faulty switch, or a loose/pinched wire.
Not sure why you would need to "Replace the voltage regulator rectifier" which really sounds more like a guess to me ;-). Anyhow, you can now download the SM for the FZ6 from this page Yamaha FZ6 under the Documents Header. Page 402 shows you the diagram for the signaling system.
Fue útil esta respuesta?
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 38
Todo El Tiempo: 802
