Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El OnePlus Nord 2 5G es un smartphone de gama media lanzado en julio de 2021. Es el sucesor del OnePlus Nord, cuenta con una pantalla Fluid AMOLED de 6.43" a 90 Hz y utiliza un chipset MediaTek MT6893.
How to replace USB-C port?
My charging port has become loose and requires moving the cable or holding the phone at an awkward angle to charge. I've checked, it happens no matter what cable I use.
How would I go about replacing the port to ensure charging is reliable?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Alex,
You're actually lucky with regard to your charging port in that your phone is one of the very few that has the port itself alone on a flex cable, making it a very straight-forward replacement that won't affect anything else in the phone. Well, that assumes you take apart the phone and put it back together correctly and without damaging anything in the process.
As I mentioned, the port itself is on a long flex cable that runs under the battery to the motherboard. You can find replacement parts on all the big sites like Amazon, eBay and AliExpress, but here's an example that came up on my cursory search.
OnePlus Nord 2 5G Charging Port Replacement - Cellspare
I didn't find any iFixit-style guides to doing that repair, but I ran across one for the Nord 2 non 5G model that's very similar and will give you the outlines of the procedure. It's in Spanish but the Google Chrome web browser's language translation makes it very usable.
Manuals / OnePlus Nord 2 / Charging flex - Nobody Calls Me Chicken
I'd suggest you start out by following the iFixit guide to replacing the battery, followed by the daughter board replacement guide; that should get you at least 90% of the way to being able to swap out the charging port flex cable assembly; using the first guide I mentioned as an example should get you the rest of the way.
OnePlus Nord 2 5G Battery Replacement - iFixit Repair Guide
OnePlus Nord 2 5G Daughterboard Replacement - iFixit Repair Guide
As you work, take lots of pictures then you can use those to create your own charging port replacement guide here on iFixit. It's easy, fun, and will earn you the gratitude of those who come after you with the same problem.
Create a new Guide - iFixit
Good luck; let us know how it goes, and feel free to ask if you have any questions.
Imagen de OnePlus Nord 2 5G Batería
Guía
Reemplazo de batería del OnePlus Nord 2 5G
Dificultad:
Moderado
45 minutes - 1 hour
Imagen de OnePlus Nord 2 5G Placa secundaria
Guía
Reemplazo de la placa base secundaria del OnePlus Nord 2 5G
Dificultad:
Moderado
40 minutes - 1 hour
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Just curious since im gonna do this myself soon
Is there 1 big differenxe in al the different brands of those replacement cables or does it not matter that much?
- de
@jens77381 Of course, as with anything there's always a chance of getting a crappy part that doesn't work like it's supposed to, but in general I'd say I've had pretty good luck with my purchases whether they've been from Amazon, eBay or AliExpress. You'll probably find the better quality items on Amazon plus you can read reviews, but you can save a lot buying from AliExpress at the expense of wait times and sometimes lower quality. eBay is somewhere in the middle; basically you tend to find middle-of-the-road quality, prices and shipping times.
All in all, I tend to go for the more inexpensive parts when I have the luxury of waiting for them to ship from China, then from eBay if I don't want to wait quite that long, and finally Amazon if I'm in a hurry and don't mind paying more.
Of course, with a part like this that's not expensive I might tend to go for the fast shipping but sometimes I just say what the heck and go ahead and order it from China if I have the time.
- de
Añadir tu respuesta
Alex Higgs estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 32
Todo El Tiempo: 3,909
