Saltar al contenido principal
Repair guides, user manuals and services for the Asus ROG Zephyrus G14 laptop. The Zephyrus G14 is a 14-inch Ryzen-powered gaming laptop, first released in mid-2020.
Preguntas 20 Ver todo
keyboard is dead and backlight is flickering
Hi, some history of my g14 2022, after 10months, my lcd started to have lines, had it replaced by the shop i bought this from. then in one of my travel, my laptop bag fell with my g14 in it, after that, the keyboard stop working adn there is also a slight backlight flicker
. i had to use an external keyboard. i tried to have the keyboard replaced but the repair shop said even with a new keyboard, it still doesnt work. any lead will be appreciated
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@walterjrgarcia the backlight flickering and keyboard not working could be a torn, loose cable as well as damage to the board connector etc. I suggest that you take a look at those things first. Remove the bottom case as show in step one on here Reemplazo de pasta térmica para Asus ROG Zephyrus G14 check closely for any damage. Post some pictures of what you see with your Question. That way we can see what you see. Agregar imágenes a una pregunta existente
Worst case scenario would be a new keyboard (upper case) or even a new motherboard. Let's check this all out first.
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Asus ROG Zephyrus G14 Pasta térmica
Guía
Dificultad:
Moderado
45 minutes - 1 hour
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Walter Jr Garcia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 252
