Saltar al contenido principal
Modelo núm. A1367 / Capacidad de 8, 16, 32 o 64 GB
Small metal clip on digitizer?
Does anybody know if you can purchase the small metal clip thats fits onto the digitizer. Located by the cables with cutouts for the camera and flash.
They do not come with the new screen
Thank you
Martin
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
Solución Elegida
I would not care to put that part back as in my opinion the new screen fits better without it. Just use enough adhesive and make sure everything is plane and the screen will sit perfectly. Read our discussion about this here:
What parts to move from the broken screen?
~asle
Fue útil esta respuesta?
Puntuación 0
Nothing i know of. fix i pod touch 4 gen without it. screen fix better. works ok without.
Puntuación 0
1 comentario:
To be honest this piece is important in supporting the screen right where there is a gap under it. Without the piece, pressure on the exact spot would (more) easily break the glass. But if the piece is bent it will be harder to get a good fit. So you would never notice the piece is gone except if you put pressure on the spot.
- de
Añadir tu respuesta
martin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,031
