Hi @paulmathias
Looking at images of the switch used in the model it looks like it is a double pole, single throw type i.e. two inputs and two outputs.
In your machine this means both the Active and the Neutral would be connected through by the switch being operated
With the power disconnected from the machine and with the DMM connected between one input terminal and the appropriate output terminal, when the switch is operated there should be a "beep" heard from the Ohmmeter. Then connect the Ohmmeter across the other input and output terminals to make sure that when operated they make as well i.e. beep heard.
Check that the beep works first by shorting the Ohmmeter test leads together. If for some reason the meter doesn't beep when its test leads are shorted together then the meter should measure 0.00 Ohms (meter set to Ohms x1 scale) when connected across either of the input/output connections with the switch operated
If not at all or if only on one input/output connection then the switch is faulty and will need to be replaced as both need to be working for power to reach the power board.
Search online for Delonghi ESAM 6900.M power switch, to find suppliers that suit you best.
Note: It may be just a mechanical fault in the switch i.e. broken or perhaps burnt out contacts, although hopefully not the latter as usually contacts shouldn't burn out so there may be something else that is wrong. I don't know the machine but can you turn off the machine first using the control panel controls and then turn off the power switch? If so if you always turned it off using only the power switch then this may be a contributing factor to the contacts burning out, but this is only a guess. You would have to open the switch first, to see what the problem is.
2 comentarios
Hi @paulmathias,
Do you have a DMM (digital multimeter)?
If so disconnect the power to the machine and use the DMM's Ohmmeter function to check if the Power On/Off switch is OK when it is operated i.e. continuity through the switch when it is operated.
If it is then please post an image showing where the wiring from the on/off switch connects to the Power board.
Looking at images of the power board online (yours don't show the full image) I can't see where the power connects to the board and also I can't see any input fuses or MOVs on the board either
- de jayeff
I managed to fine a DMM, and dust it off.
I've taken a few photos and attached them to the original post.
1. is of the switch.
2. is of where the L and N connect to the board.
3. is a close-up of the L terminal (F5)
4. is a close-up of the N terminal (F4)
5. is across where I did the continuity test, with the main switch in the ON position - no beep.
It looks like the main switch is U/S. Is that likely?
- de Paul Mathias
